mason Posted October 22, 2010 Posted October 22, 2010 My 2002 Lemans has been intermit. hitting the rev limiter at around 5500 RPM. It will work fine then sometimes when I really get on it, it kicks in way too early. I have a power cammander, but other than exhaust it is completely stock. Wonder if anyone else has experienced this and if there are any suggestions.... thanks
fotoguzzi Posted October 23, 2010 Posted October 23, 2010 strange.. Only thought I have is disconnecting the battery for awhile and hope the CPU does a re-set?
GuzziMoto Posted October 23, 2010 Posted October 23, 2010 How do you know it is the "rev limiter" you are hitting?
raz Posted October 24, 2010 Posted October 24, 2010 Among many things, a clogged fuel filter can act as a rev limiter. Another not too uncommon cause is solenoid (fuel tap) malfunction - the pump can suck it open but you will have fuel starvation.
mason Posted November 4, 2010 Author Posted November 4, 2010 I don't know for sure it is the Rev Limiter, but it does act exactly like it does where it usually kicks in. It is very random and after letting off the throttle it seems fine and will even rev past that point a few seconds later. I doubt my filter has ever been changed, with the bike having 19k on it.
raz Posted November 4, 2010 Posted November 4, 2010 Try swapping all five-pin relays around, round-robin. If you have some electric cleaner spray (preferably not WD-40 or the likes with oil in them) you could spray the relay sockets while at it. Chances are problem vanishes. Best of all, this cost you nothing to try!
Dan M Posted November 6, 2010 Posted November 6, 2010 +1 on the fuel starvation. Check the filter. Check power and ground to the pump also. 02 has a manual fuel tap - no worries there unless it is partially closed.
luhbo Posted November 6, 2010 Posted November 6, 2010 ... I have a power cammander... ... and you have a problem. Maybe the problem will go with the Power Commander? It's worth a try, it wouldn't be the first time. Hubert
helicopterjim R.I.P. Posted November 8, 2010 Posted November 8, 2010 Does your airbox have the lid removed? If so, check to see if the heatshield fabric lining the underside of the tank isn't coming loose and plugging the intake!
mason Posted November 13, 2010 Author Posted November 13, 2010 Thanks, I will try some suggestions this weekend, see what happens.....
mason Posted November 22, 2011 Author Posted November 22, 2011 Just to follow-up on this problem, the problem was indeed the power commander. After removing and reinstalling the power cammander serveral times and watching the problem come and go with the PC, thereis no doubt the PC was causing the problem. thanks
plexiform Posted June 21, 2017 Posted June 21, 2017 Was pushing the 02 Scura a little on the highway today and hit the rev limiter at ~6-7k RPM (I am not certain of this so it could have been slightly higher)....when should it kick it? I've never had that happen before. I've never really pushed the bike before. Actually I didn't really think I was pushing it that hard when it happened. I searched 'rev limiter' and came up with this link and another not related to V11's. Wondering if anyone knows when the rev limiter should kick in so I can make note of the exact RPMs next time. I do not have a Power Commander, just changed the starter, recently upgraded to OMRON relays, any thoughts are appreciated? To keep things in perspective, it has happened only once so far.
MartyNZ Posted June 21, 2017 Posted June 21, 2017 I've hit the Rev limiter on my bike a few times before I got used to the bike. I don't believe that there is much point being on the red line when you have 6 gears. The Ti ECU apparently has a 500 rpm higher limit than stock, but I haven't checked if this is retained in Meinolf's maps. http://www.v11lemans.com/forums/index.php?showtopic=17133&page=2&do=findComment&comment=184022 http://www.v11lemans.com/forums/index.php?showtopic=18440&do=findComment&comment=196546
Meinolf Posted June 21, 2017 Posted June 21, 2017 Hi, the standard 15M/RC Bins stop injecting fuel at 8398rpms and begin injecting again at 8301rpms. The TI Bin values are 8600/8398rpms. Cheers Meinolf 3
plexiform Posted June 21, 2017 Posted June 21, 2017 thanks for the info. I think I underestimated how hard I was pushing it in the morning. On the way to work tonight it was fine all the way to 8k without issue.
