rossi46 Posted November 14, 2010 Posted November 14, 2010 Hi After 2 near misses with an ABBA stand- luckily no damage- I've got ZERO confidence in it! I am thinking maybe the MG or http://www.becker-technik.de/Central-Lifter/Central-Lifterenglisch/body_central-lifterenglisch.html any thoughts? thanks
Kiwi_Roy Posted November 14, 2010 Posted November 14, 2010 Hi After 2 near misses with an ABBA stand- luckily no damage- I've got ZERO confidence in it! I am thinking maybe the MG or http://www.becker-technik.de/Central-Lifter/Central-Lifterenglisch/body_central-lifterenglisch.html any thoughts? thanks They look like a great idea, I think the use of 2 sockets for the mounting would work really well. For winter storage I would tie it back to the frame to prevent accidental unloading. Roy
guzzimeister Posted November 14, 2010 Posted November 14, 2010 Hi After 2 near misses with an ABBA stand- luckily no damage- I've got ZERO confidence in it! I am thinking maybe the MG or http://www.becker-technik.de/Central-Lifter/Central-Lifterenglisch/body_central-lifterenglisch.html any thoughts? thanks Hi the Becker stand although quite clever does not look like it has any leverage points to help you get it onto the stand. I have fitted a centre stand to my V11, but before I fitted Hepco and Becker luggage to it and gained a few rails as grab points, it was nearly impossible to use. There are no really solid grab points von the rear of a V11, they are all shrouded by brittle plastic. It is very difficult to use now as the balance points which are in the same pivot area as the Becker stand are too far back so you are effectively trying to lift 100 kilos onto the stand. The Guzzi stand is better as it comes with a long lever which makes flicking it onto the stand far easier, definitely a one man job. Last time I bought one was in 2001 and it was £60. If you know a friendly welder it would be easy to reproduce.I'm not sure you could buy one now that the bike has been out of production for 4+ years. It comes with a bar to but under the front of the sump to put the front wheel up too. Good luck Guzz
stockport claret Posted November 15, 2010 Posted November 15, 2010 I use a Micron paddock stand to lift the rear wheel off the ground. All I had to do to make it fit was to pull the uprights a bit further appart. If you want to to take the shock and swing arm out then you may want to look at something like this which you could use on the bar inbetween the pork chops.
Guzzi2Go Posted November 15, 2010 Posted November 15, 2010 I have the Becker stand. It basically works, but I had to remove the wheels to get it working. Otherwise it just keeps sliding with the bike as you try to lift. Not totally effortless, but it will work provided that you push the bike backwards as you stand on the lever. Also, they are a bit fiddly to place/remove. Quite heavy (read German-solid) too.
luhbo Posted November 15, 2010 Posted November 15, 2010 The becker lift/stand is the most easy to use stand I know for the V11. The trick is, as with Nortons, don't use brute force. The wheels make the thing even easier to work with. Just put your weight on the far end of the stand - as with every motorcycle stand since they were invented. hubert
Buzzard Posted November 15, 2010 Posted November 15, 2010 If you want to to take the shock and swing arm out then you may want to look at something like this which you could use on the bar inbetween the pork chops. I built a rack out of 1 1/2"x1/4" strap steel that does much the same thing as this BikeTek stand. I use it with one of those large floor jacks with a 2'x 2' pad which raises up. Very stable. I would have bought this BikeTek if I would have known about it. The only misgiving I might have with it is the overall stability, due to lack of size of it's base. It is a very neat arrangement for working on the Guzzi, front or rear. I do prefer the rear swingarm lift for oil changes, nothing in the way of the intended work area. I just checked on eBay, the BikeTek lift is available for about $130 incl shipping. I imagine I would bolt the lift to a piece of stout plywood for steadiness, hate to have the bike roll forward or back while in the air. The ad states that the yokes are adjustable for width and heighth. Good for up to 13" width, the Guzzi is about 12 3/4" between, so it might just fit.
felix42o Posted November 15, 2010 Posted November 15, 2010 I have the Pitbull stand, and have no complaints. It's well built, and doesn't slide around. Doesn't work for the front, but I have other methods for that.
Guzzi2Go Posted November 16, 2010 Posted November 16, 2010 The becker lift/stand is the most easy to use stand I know for the V11. The trick is, as with Nortons, don't use brute force. The wheels make the thing even easier to work with. Just put your weight on the far end of the stand - as with every motorcycle stand since they were invented. hubert I guess I don't weigh enough...
docc Posted November 17, 2010 Posted November 17, 2010 The becker lift/stand is the most easy to use stand I know for the V11. The trick is, as with Nortons, don't use brute force. The wheels make the thing even easier to work with. Just put your weight on the far end of the stand - as with every motorcycle stand since they were invented. hubert I guess I don't weigh enough... You skinny Westphalians! Come to America - we will fatten you up and your stand will work better (while your suspension may not)!
Guzzi2Go Posted November 17, 2010 Posted November 17, 2010 You mean the stand would turn into a catapult. Why not. Why not...
rossi46 Posted March 18, 2011 Author Posted March 18, 2011 Thanks for the input guys - I finally went for a Becker stand- nice bit of kit,I too had trouble getting it up so I just tightened the wheels to stop them rolling-oil change on the weekend then
Trevini Posted March 18, 2011 Posted March 18, 2011 Slightly off topic, but how do you find the Conti R/As for handling on the V11? I've used them before on my TDM and really like them. Trev
rossi46 Posted March 19, 2011 Author Posted March 19, 2011 TREVINI tyres are great-no probs even in heavy rain
Trevini Posted March 19, 2011 Posted March 19, 2011 TREVINI tyres are great-no probs even in heavy rain Thanks
