  • 1 month later...
  • 4 months later...
Two new slideshow videos - Internal Fuel Pump Unit & Double Cardan Universal Joint Assembly
  • 1 month later...
  • 4 months later...
  • 5 months later...
My dad has one of these, and it runs lean. Lean as in pinging.
I've offered to do a service (oil/filters/valves etc).
My question is: can I also read out this ECU using Guzzidiag and my V11 cable? Is the ECU also a 15x unit like the V11?
Does anyone know the TPS settings?
Tinus, I would contact Beetle.  He will likely have a map for that.  You might search here or on Wild Guzzi to contact him.
The other possibility might be to get a Power Commander.
Anyone else who has some knowledge about the TPS setting and readout using GuzziDiag?
I don't live near the bike...
First thing to do is change out the fuel filter and measure the fuel pressure if you can before going down the re-flashing the map path.
Intent was to do a full service first, if required (history-based) change the filter as well (it's an in-tank unit, isn't it?), but why are you suggesting to measure fuel pressure?
Once the revs are up high enough, she pulls as expected. The pinging is only on >50% throttle at rpm 3000-5000, after that it's gone as well.
It needs a full service anyway, as last was 02-2019.
I would think @biesel would know these tuning parameters such as the TPS setting and if the CO Fuel Trim can be set easily with guzzidiag.
