It's a bit slow around here so I will go over my relay upgrade.
I removed the relay bases then attached a resistor and LED to each of the 87 contacts. The 87 contact only has power if the relay is energized and the contact is closed. Now I can tell as a glance if one of the relays are out of order.
Normally when you turn the key on relays R2, R3 & R4 power up then a split second later R5 picks up for a couple of seconds (primes Pump)
Press Start R1 picks up R2 drops out, and R5 picks up
When running R2, R3, R4 & R5 are on.
Sure beats blindly shuffling relays.
Relay Base LEDs.pdf
While you are about it, a good time to check the other relay connectors for tightness
Relay Base Repair.pdf
Enjoy the light show :oldgit:
..... and you will have a couple of dozen available for spring when the Stradavarious gang meets at Valley Moto Guzzi?
I will show you my lights if you will show me My ECU :rolleyes:
..... OK but that other KIWI Dave will get jealous!!
