Kiwi_Roy Posted March 27, 2011 Posted March 27, 2011 I posted this here again because I couldn't find an earlier link Relay Base Repair.pdf Roy
GuzziYang Posted June 10, 2011 Posted June 10, 2011 I posted this here again because I couldn't find an earlier link Relay Base Repair.pdf Roy Thanks so much that's great info to know, so which relay are you supposed to replace it with?
Kiwi_Roy Posted June 11, 2011 Author Posted June 11, 2011 [ Thanks so much that's great info to know, so which relay are you supposed to replace it with? These are the ones I bought http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=Z2247-ND Omrons, made in USA Buy all SPDT type, they work for any position www.digikey.com they also have the little microswitches "Cherry"that go in your levers
twhitaker Posted June 26, 2011 Posted June 26, 2011 http://www.dpguzzi.com/ Pyro Dan sells them for about $4.00 as well as the clutch and brake lever switches.
