Here's a way you can upgrade your headlight using just one relay. The Low beam is wired to the Normally Closed contact and the High beam is wired to the Normally Open contact
This circuit uses the existing fuse and headlight relay but bypasses the main current around the small wiring and dimmer switch.
Headlight Relay.pdfFetching info...
Cool. Sometimes it's really tricky to find room for two relays where you want them, this will solve that. But you won't be able to turn lights off (I know on some bikes you already can't)
Here in Canada we don't have a light switch, it's manditory to have the headlight on for bikes and cars. I think the US are starting to follow suit.
I'm in favour of that.
Roy
