stormsedge Posted April 15, 2011 Share Posted April 15, 2011 Think I see the answer in an earlier thread...Helicoil M6 coarse for valve covers, right? k Link to comment Share on other sites More sharing options...
gstallons Posted April 15, 2011 Share Posted April 15, 2011 Yes, buy the kit........ They will come in handy. Practice on a junk part FIRST........ Link to comment Share on other sites More sharing options...
stormsedge Posted April 15, 2011 Author Share Posted April 15, 2011 Ok, thanks...last couple of threads finally gave up. k Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted April 15, 2011 Share Posted April 15, 2011 Because the head is at an angle it's hard to judge when you have the drill / tap square on, next time I do one I will try to figure out some sort of mandrill e.g. something like a block of metal that has been drilled square on a bench drill. Failing that have something square attachced to one of the other screw holes as a guide. Link to comment Share on other sites More sharing options...
stormsedge Posted April 15, 2011 Author Share Posted April 15, 2011 Ah ha! Good advice. Believe I could stack my old cylinder protectors as a guide. k Link to comment Share on other sites More sharing options...
raz Posted April 16, 2011 Share Posted April 16, 2011 I have managed to helicoil a couple of cylinder studs. You can bet I was worried about the angle! Link to comment Share on other sites More sharing options...
Dan M Posted April 17, 2011 Share Posted April 17, 2011 Ah ha! Good advice. Believe I could stack my old cylinder protectors as a guide. k That is a good idea if you don't have a drill guide. Although in this case, since you have an existing hole that you are just enlarging the bit is going to follow it straight so long as you don't force it. Tape your bit so you don't go too deep. Link to comment Share on other sites More sharing options...
