Arnaud Posted April 20, 2011 Posted April 20, 2011 Hi, I have a 1998 1100 sport I I've just installed the system of cliff jefferies My16m (I bought it 2 years ago but I didn't take time to install) with oxygen sensor and LC1 wide band controller. I've got several problems: -idle is not stable. -as soon i try to open the throttle at the max position, the engine stop until the moto is at stop or there are some explosions at the exhausts. Unfortunately, i could'nt try my motorbike with the original ECU , it is HS (It was the reason, I bought My16m) I live in Belgium , is someone can help me.? Thanks Arnaud.
emry Posted April 20, 2011 Posted April 20, 2011 MyECU Fourm Cliff has a forum, some quick searches there will most likely yield you some good information. Several other members from here are also active there. From your initial post you did not indicate if you have made any change to the mapping in MyECU. The map that Cliff provides is close for most, but in some cases it may take considerable work to get it right.
Kiwi_Roy Posted April 21, 2011 Posted April 21, 2011 Yes, post on the MyECU site. They sorted mine out pretty quick.
Arnaud Posted April 21, 2011 Author Posted April 21, 2011 no change was made on the map. I am going to do it. Thanks
