The conclusion from previous research etc was that there is no rebuild kit available.
You need to buy a whole new calliper. (And so do I)
Don't know about F08. Tonti front caliper?
P32B GOLDLINE
Here are part numbers, but I don't think that anyone was ever able to get them. A safety/liability issue?
______________________________________________________________
http://www.ducatisti.co.uk/forum/technical-help/6436-has-anyone-rebuilt-brembo-goldline-caliper.html
Parts here? > http://www.yoyodyneti.com/category.aspx?categoryID=3017
See here > http://www.v11lemans.com/forums/index.php?showtopic=10837&st=15
OK, I misread something so that's how I came up with the F08.
P32B then.
Yoyodyne's got the whole caliper for $88 and MG sells it $106 I believe with pads.
I cleaned the caliper last year but it was still noisy so now I'll give the whole system a good flushing.
Could be the master as well I suppose.
P32B then.
I was going to say that if you need one and cant find one I have a used caliper and master cylinder lying around collecting dust.
P32B then.
Thanks, I'll keep that in mind!
FO8 (P8) were fitted to early Tonti big blocks; T3, LM, G5 etc etc.
KB :sun:
So you're saying I should have one of those as well?
Alright then, if I must, I must! :thumbsup:
I could tell the wife it's a parts bike. :not:
Have you tried just swapping the pads for new ones? I tried to save money and bought cheap pads once and they make noise and dont really work that well. My motto is when the solution to the problem isnt clear to always try the easiest remedy first.
  • 3 years later...
