Hi Can someone explain what a eprom chip will do? Is it a worth while mod? or should I save my pennies for a x over?thanks
There is no eeprom chip option for your ECU. You can get it reflashed.
The EPROM chip in your ECU holds the program (Map) for the fuel and ignition, it can be re-programmed with a different map just like your computer can be upgraded with the latest Windows software.
Yes you should get a Mistral x-over.. it solved a lot of running issues in the 3-4k rev range for me.
cheers, I did wonder if the seller (eblag) thought it was a 1100 sport, fotoguzzi thats exactly what I'm after! I might have to put up with it awhile longer as I've just sprung from motogp tickets! :rolleyes:
