Lucky Phil Posted September 12, 2023 Posted September 12, 2023 3 hours ago, audiomick said: Could you tell me (us) which part number you are referring to? The parts must be on this diagram: https://wendelmotorraeder.de/schaltung-v11-02-le-mansskura-ex-30_3006_300602_30060203_3006020330_300602033012.html I expect to be going in there in the foreseeable future (maybe this winter), and would like to have those sort of things ready to go before I start. PS: How does one do that? Item 13 Mick. I'd buy 2 but unless you're a ham fisted moron then snap rings/Circlips like these can be reused many times. Phil 1
audiomick Posted September 12, 2023 Posted September 12, 2023 Thanks Phil. I like to think I'm not a ham-fisted moron, but I have managed deform circlips in the past. Maybe I'll get a couple in just to be on the safe side.
docc Posted September 12, 2023 Posted September 12, 2023 If I recall correctly, and per @mznyc's clarification post, this image shows the neutral position: And this is first gear: 2
audiomick Posted September 12, 2023 Posted September 12, 2023 That's curious. The manual starts off the gearbox disassembly section with "make sure the gearbox is in neutral" page 326 here https://guzzitek.org/gb/ma_us_uk/1100/V11_1999-2003_Atelier(Compil-GB-D-NL).pdf and when they get around to refitting the selector on page 348, they talk about lining up the dots, and "Important: The fitting procedure for the pre-selector cover must only be carried out when the gearbox is in neutral." but the lined up dots is actually first gear?
docc Posted September 12, 2023 Posted September 12, 2023 That is my recollection, yet it has been a while since I was in there. Take a look at the discussion on the first page where @mznyc clarified his markings. As always, y'all check my work. . .
audiomick Posted September 12, 2023 Posted September 12, 2023 16 minutes ago, docc said: ...the first page where @mznyc clarified his markings. Yeah, he talks about putting it in first, and maintains that the dots line up in first. Baldini, however, wrote that the box should be in neutral to re-fit the selectors. As I wrote, curious. Has anyone been in there recently and can clear my confusion?
MartyNZ Posted September 12, 2023 Posted September 12, 2023 Neutral shown, marks align when in first gear. Docc is right (again). I think it's best to fit the plate with the gearbox in neutral and the plate set as shown. 1 1
audiomick Posted September 12, 2023 Posted September 12, 2023 Thanks Marty. Then the workshop book seems to be misleading or incomplete(or I didn't read it thoroughly enough). Who would have thought...
Lucky Phil Posted September 12, 2023 Posted September 12, 2023 2 hours ago, audiomick said: Thanks Marty. Then the workshop book seems to be misleading or incomplete(or I didn't read it thoroughly enough). Who would have thought... I've done a few of these and my recollection is the dots line up in neutral and not all cam wheels have dots either. There are variations. Early selectors without the banana support and non adjustable overtravel pin and the later adjustable pin and banana support plate and as well as that there was an update kit sold for the earlier gearboxes that included a new cover, adjustable pin and banana plate. Phil 2
audiomick Posted September 12, 2023 Posted September 12, 2023 So the moral of the story seems to be, read everything here and everywhere else you can find good info, believe it all, and then have a look for yourself and think very carefully about it all despite what you have read up til then. 2
docc Posted September 13, 2023 Posted September 13, 2023 Same neutral position added markings on my ~2002 banana plate selector . . . 1
Lucky Phil Posted September 13, 2023 Posted September 13, 2023 2 hours ago, audiomick said: So the moral of the story seems to be, read everything here and everywhere else you can find good info, believe it all, and then have a look for yourself and think very carefully about it all despite what you have read up til then. Pretty much. I did a how to post years ago. It's all pretty straight forward. High points Don't attempt to adjust the main eccentric adjuster on the bike. It's a bench adjustment only despite what people do. The shift returns spring on the stop plate assy can be installed upside down. When installed wrongly the spring arm rubs on the cover The pawl arm over travel stop if adjustable should be .60mm clearance at the minimum point in the travel Fit a scudd needle roller to the detent drum Fit a Chuck spring Check the pawl arm is straight and fine finish the contact faces. Phil 3
stewgnu Posted September 27, 2023 Posted September 27, 2023 On 9/13/2023 at 2:32 AM, Lucky Phil said: Pretty much. I did a how to post years ago. It's all pretty straight forward. High points Don't attempt to adjust the main eccentric adjuster on the bike. It's a bench adjustment only despite what people do. The shift returns spring on the stop plate assy can be installed upside down. When installed wrongly the spring arm rubs on the cover The pawl arm over travel stop if adjustable should be .60mm clearance at the minimum point in the travel Fit a scudd needle roller to the detent drum Fit a Chuck spring Check the pawl arm is straight and fine finish the contact faces. Phil cheers for your write-up on the gearbox phil- got me thru it. It was only after i re-re-read it that i realised i should’ve draw-filed the bearing surfaces- i polished them but probably put a slight radius on them. Working bloody lovely though now 🙂. Makes me appreciate the v11 setup as when it’s good it’s very good. I got a vfr400 this year and the action thru the box is no comparison. Which i wouldn’t have expected as when i saw inside the v11 guts it looked so… agricultural? 3
