docc Posted September 5, 2011 Share Posted September 5, 2011 Other than the UFI, the Champion made filter available at WankMark (Super Tech ST3614) has been referenced here before. I had my local Oh,Really parts store cross reference to a WIX. I am under the (perhaps misled) impression that WIX makes a good reliable filter. (They say : WIX 51348) The question is, what does it otherwise fit? They listed SAB/CHR/TOY '67-'09. Whatever that means. Link to comment Share on other sites More sharing options...
docc Posted September 5, 2011 Author Share Posted September 5, 2011 OK, well, there's this: Part Number: 51348 UPC Number: 765809513488 Principal Application: Various Chrysler/Dodge/Jeep (82-11), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-11), Ford (03-11), Mazda, Mercury (05-11), Yugo (86-89), VW (09-11) Various Lawn&Garden, Farm, HD Equipment All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.404 Outer Diameter Top: 2.921 Outer Diameter Bottom: Closed Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/20 Burst Pressure-PSI: 275 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.734 2.430 0.226 __________________________________________________________________________________________________________ FWIW, I'm thinking it a good indication that Saab specified the filter for so long ('67 -'09) as well as Volkswagen more recently. That both Saturn and Jeep/Chrysler as well as Suzuki and Toyota have used it so long (20-30 years) should make it ever available. Link to comment Share on other sites More sharing options...
twhitaker Posted September 6, 2011 Share Posted September 6, 2011 OK, well, there's this: Part Number: 51348 UPC Number: 765809513488 Principal Application: Various Chrysler/Dodge/Jeep (82-11), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-11), Ford (03-11), Mazda, Mercury (05-11), Yugo (86-89), VW (09-11) Various Lawn&Garden, Farm, HD Equipment All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.404 Outer Diameter Top: 2.921 Outer Diameter Bottom: Closed Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/20 Burst Pressure-PSI: 275 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.734 2.430 0.226 __________________________________________________________________________________________________________ FWIW, I'm thinking it a good indication that Saab specified the filter for so long ('67 -'09) as well as Volkswagen more recently. That both Saturn and Jeep/Chrysler as well as Suzuki and Toyota have used it so long (20-30 years) should make it ever available. I use a Mobil M1-102 filter in my Guzzis. Link to comment Share on other sites More sharing options...
The Monkey Posted September 6, 2011 Share Posted September 6, 2011 Thanks Docc, good to know for the long run. Here are alternates for the UFI Fuel filter UFI 3150100 Baldwin, BF 836 Bosch, 0 450 905 002 Cheers Link to comment Share on other sites More sharing options...
guzzimeister Posted September 6, 2011 Share Posted September 6, 2011 Thanks Docc, good to know for the long run. Here's an alternate for the UFI Fuel filter UFI 3150100 Baldwin, BF 836 Cheers Hi chaps the Wix filter is OK, it's standard European auto aftermarket spare. I've used it plus Halfords HOF218 in muy bike no probs. If I'd put it in my car, I'd put it in my bike. Filter for the Euros among us is used on a Fiat Panda 85 onwards. Note Champion quote F107 as a fitment for this but it won't fit a V11, too tall. Cheers Guzz Link to comment Share on other sites More sharing options...
docc Posted September 6, 2011 Author Share Posted September 6, 2011 Thanks, guys. I suppose I'll carry in my spare SuperTech and do a comparison. I thought about cutting them open for a look, but not likely. Nice to know what these bits fit in the case of walking in the door of the parts store with no numbers. I use a fuel filter for Isuzu Trooper (like , all years) and, apparently a Saab oil filter (like, all years!) Off to Oh, Really's for this months oil/filter special on my new oil-of-choice: Mobil 1 V-Twin 20w-50 SG. Link to comment Share on other sites More sharing options...
Dan M Posted September 7, 2011 Share Posted September 7, 2011 I did an interchange. Here's a couple more: A/C Delco PF53 Car Quest 85348(premium) / R85348(economy)- both made by WIX HIC CF3614 Very common filter. Link to comment Share on other sites More sharing options...
docc Posted September 8, 2011 Author Share Posted September 8, 2011 So, the trouble seems to be clearance for filter height. The SuperTech (USA built Champion from WalMart) looks to be some 3.120 inches (7.88 cm) and the WIX 51348 looked much taller. I had O'Reilly's show the filter for Guzzi applications. All models were the same WIX 51215. (Hecho en Mexico) It is also taller than the ST by about 7mm or 9/32" (3.404 inches). The WIX specs state this filter (51215) is for Buell/HD/Dixie Chopper. The only difference I see in the specs is the Burst Pressure/PSI which is 325 for the 51215 and lower for the "Saab" filter (51348): 275 psi. EDIT: also, the WIX 51215 is more heavy duty construction than the SuperTech/Champion weighing 252 grams to the ST's 189 grams. What about the height? What is the height on the UFI? Link to comment Share on other sites More sharing options...
Dan M Posted September 9, 2011 Share Posted September 9, 2011 I keep the CarQuest 85348 (WIX made - 51348 equivalent) on hand - it measures 3.40" My bike currently has a UFI installed and is due for a change. If no one gives the spec, I'll measure it and post when I change oil. I have to think 1/4" is not an issue. Link to comment Share on other sites More sharing options...
The Monkey Posted September 9, 2011 Share Posted September 9, 2011 Height on UFI oil filter is 91mm (3.56 inch) Thats overall including the 2mm gasket Link to comment Share on other sites More sharing options...
docc Posted September 9, 2011 Author Share Posted September 9, 2011 Thank you, gentlemen! The WIX looks so much better built, larger, and heavier that I think I'll install it instead of the ST. The Porsche site I linked references WIX as an acceptable replacement part. (I'm thinking Porsche people might be even pickier than Guzzi people some of whom have been to known to use those filter canisters that use toilet paper rolls ). Thanks for the feedback! Link to comment Share on other sites More sharing options...
rossi46 Posted September 10, 2011 Share Posted September 10, 2011 just spotted this, anyone used one? My link Link to comment Share on other sites More sharing options...
