Is there a battery charging indicator light on the '04 Le Mans? My bike has both left and right turn indicators, high beam, neutral, low fuel and low oil for a total of 6 indicators. My friend's '00 Sport has only one turn indicator and a charging light is included among the other 6 lights.
Coming out of the voltage regulator there's a pair of wires Black & White
The Black wire is the Voltage reference the White one is for the charge light. If you unplug the wires and turn on the key
you should be able to measure 12V on the white wire (loom side) and if you ground that wire it will make the light go.
If you don't detect 12V either the lamp is burnt out or there isn't one.
If the light works when you ground the white wire but never works normally it's possible the switch in the reg is burnt out.
Don't worry about it as long as the bike is charging, the later bikes don't have a light
