tikkanen Posted October 5, 2011 Posted October 5, 2011 Good to see you back in the fold, Slavomir And good luck with your 1100 Sport, it's a cracking good looking bike and I'm looking forward to seing the end result. Best of luck Søren
Slavomir Musilek (R.I.P.) Posted October 31, 2011 Author Posted October 31, 2011 engine blasted with dry ice, carbon sediments on piston (3-4mm thick) are gone!
savagehenry Posted November 1, 2011 Posted November 1, 2011 You motorcycle nutjobs never cease to amaze me
Slavomir Musilek (R.I.P.) Posted November 1, 2011 Author Posted November 1, 2011 On 11/1/2011 at 12:26 AM, gstallons said: You did what ??????? with the dry ice..... you know sand blasting - this is blasting with dry ice, it blasts away any resistances like oil, dust etc, then evaporates. So you don!t have to tear the engine apart to pieces. dry blasting on Wiki and you see the result
gstallons Posted November 1, 2011 Posted November 1, 2011 Do you own or rent the equipment to do this? This looks like the way to go.........
Slavomir Musilek (R.I.P.) Posted November 1, 2011 Author Posted November 1, 2011 On 11/1/2011 at 1:01 PM, gstallons said: Do you own or rent the equipment to do this? This looks like the way to go......... unfortunatelly not I always use some local workshops, I believe you should have some nearby you also! It is used for cleaning various products, from kitchen and medical equipment to restorations of old "things" and ect. It is not expensive anyway, 2 Guzzi engines, 2 trannys, 1 final drive and I payed 170€
Skeeve Posted November 1, 2011 Posted November 1, 2011 On 10/5/2011 at 7:46 PM, Slavomir Musilek said: What rims are those? They look... somewhat lighter than stock?
Slavomir Musilek (R.I.P.) Posted November 1, 2011 Author Posted November 1, 2011 On 11/1/2011 at 4:19 PM, Skeeve said: On 10/5/2011 at 7:46 PM, Slavomir Musilek said: What rims are those? They look... somewhat lighter than stock? Hi Skeeve, unfortunatelly not, these are OEM wheels for first carburateur version, 120/70-17 in front and 160/60-18 in rear... S.
Slavomir Musilek (R.I.P.) Posted November 19, 2011 Author Posted November 19, 2011 no good news.. all gears look like this...
gstallons Posted November 20, 2011 Posted November 20, 2011 On 11/19/2011 at 7:53 PM, Slavomir Musilek said: no good news.. all gears look like this... What brand of gear lube & service intervals were you running on this ? What kind of symptoms were you having?
Slavomir Musilek (R.I.P.) Posted November 20, 2011 Author Posted November 20, 2011 I haven't run it, this is the Sport I bought from older Guzzista on ebay in Germany His symptomes were "bit louder 5th gear" Don't know what he has been running, he claimed that Guzzi was serviced on regular basis... But I don't blame him, he is one of the "technical type"...
Slavomir Musilek (R.I.P.) Posted January 22, 2012 Author Posted January 22, 2012 so finally some progress, new gearbox installed (helical gears) the tank has to be re-welded as the mounting bracket is damaged. Also some big load of gaskets, orings and all the stuff from Stein-Dinse is on the way. Meanwhile some photoshoping. Still not convienced about the fairing. will keep you posted.
Orson Posted January 26, 2012 Posted January 26, 2012 On 1/22/2012 at 8:39 PM, Slavomir Musilek said: Meanwhile some photoshoping. Still not convienced about the fairing. Here are some fairings I spotted at the GMG:
