Orson Posted September 19, 2011 Share Posted September 19, 2011 I was idling in first gear while making my way through some pedestrians when I heard a metalic scraping sound. I sounds just like the sound that a warped brake rotor makes. But when I pull in the clutch, the sound stops, so it s not a brake rotor. could this be the infamous single plate clutch about to expire? Bike has just over 70,000 km on it. Link to comment Share on other sites More sharing options...
gstallons Posted September 19, 2011 Share Posted September 19, 2011 Does this sound happen in neutral also? Link to comment Share on other sites More sharing options...
Orson Posted September 19, 2011 Author Share Posted September 19, 2011 Does this sound happen in neutral also? No Not in neutral also I seem to notice it when I m on a downhill, coasting while in first gear Link to comment Share on other sites More sharing options...
gstallons Posted September 19, 2011 Share Posted September 19, 2011 I would say your clutch / flywheel assembly is probably o.k. Drain a small amount of oil from the transmission ( and look at the drain plug ) to see what comes out with the oil ? Link to comment Share on other sites More sharing options...
