wizz99 Posted October 15, 2011 Posted October 15, 2011 Hi all , my bike is coming up with a error code that says there's a fault with the air temperature sensor. I checked the sensor and it looks ok , could anyone tell me the value of this air temperature sensor so i can check it , it's this one, http://www.mgcycle.com/product_info.php?products_id=1226 . Thanks Wizz99 Ps sorry just noticed i've posted it in the wrong bit of the forum should be in Technical Topics
gstallons Posted October 15, 2011 Posted October 15, 2011 Do you have access to a wiring diagram for your bike? I assume the pcm is easier to access than the air temp sensor.If you can disconnect the wiring harness and check the resistance at the pins to see if you have continuity or not. If you don't then gain access to the sensor and check it. If it is open the sensor is bad.If it is not you have problems with the wiring. p.s. I do not know what the resistance value is at ambient temperature. You should assume if it is between (for now) 100-2000 ohms it is o.k......
wizz99 Posted October 16, 2011 Author Posted October 16, 2011 Thanks for your reply , i found the values in the fuel injection manual . The sensor has failed , so i've bought a 3k NTC thermister and chopped out the old one http://www.ebay.co.uk/itm/Thermistor-3K-NTC-TT3-3KC3-BG-/320764367617?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item4aaf0bd301 . Cheers Wizz
gstallons Posted October 16, 2011 Posted October 16, 2011 Are you sure this sensor is going to have the same temp/resistance values ? Yes or No..not maybe.
Guzzi2Go Posted October 28, 2011 Posted October 28, 2011 You can find the values of the original part here: http://www.jefferies-au.org/MyECU/maps.htm
Cliff Posted October 28, 2011 Posted October 28, 2011 Here's a better link http://www.cajinnovations.com/MyECU/temperature.htm
