dave Posted December 8, 2011 Posted December 8, 2011 Does anyone know the distance between the disc mounting flanges on the front hub (not including discs)? Thanks for the help!
felix42o Posted December 9, 2011 Posted December 9, 2011 Does anyone know the distance between the disc mounting flanges on the front hub (not including discs)? Thanks for the help! I'll measure the hub I have after dinner and let you know.
dave Posted December 9, 2011 Author Posted December 9, 2011 I'll measure the hub I have after dinner and let you know. Thanks, I hope to be able to return the favor sometime
felix42o Posted December 9, 2011 Posted December 9, 2011 Dave, laying flat on my workbench the Cali hub I have is 5 9/32" wide, or 134mm give or take. Between the disc mounting flanges is just shy of 4 3/4", very close to 120mm. Hope that helps. If I get time (slight chance) before I head out on deployment next week I'll post some pics with the hubs mounted on my V11 as 'proof of concept'
dave Posted December 9, 2011 Author Posted December 9, 2011 Dave, laying flat on my workbench the Cali hub I have is 5 9/32" wide, or 134mm give or take. Between the disc mounting flanges is just shy of 4 3/4", very close to 120mm. Hope that helps. If I get time (slight chance) before I head out on deployment next week I'll post some pics with the hubs mounted on my V11 as 'proof of concept' Excellent! That is the same as a cast wheel. Thanks for the fast replies and help! I will forward any info I can as it seems we are on the same path... ok, I am trudging along behind you in your tracks
felix42o Posted December 9, 2011 Posted December 9, 2011 Dave, laying flat on my workbench the Cali hub I have is 5 9/32" wide, or 134mm give or take. Between the disc mounting flanges is just shy of 4 3/4", very close to 120mm. Hope that helps. If I get time (slight chance) before I head out on deployment next week I'll post some pics with the hubs mounted on my V11 as 'proof of concept' Excellent! That is the same as a cast wheel. Thanks for the fast replies and help! I will forward any info I can as it seems we are on the same path... ok, I am trudging along behind you in your tracks No worries. You'll likely get done well before I do, as I won't be back until mid-May and I have an R69US BMW that needs to get finished. I've been distracted by BMW's lately, entirely by accident. Here's the R90/6 I just finished; this was the one I had Woody's build a spoked wheel for.
