68C Posted July 3, 2012 Posted July 3, 2012 If you were asking about my MyECU, I built it although not without problems, as posted on the MyECU forum, had it running for a few days when it quit. Probably my assembly quality. Have just built another one and am now trying to get that to run. The TPS flying leads I added are certainly handy, for a instance - I rode around with the stock ECU and a multimeter reading the TPS voltage strapped to the tank, on the over run with a closed throttle it does not always go to the same setting as a cold stationary engine. I think it must be vacuum taking up the slack in the mechanical parts of the butterfly spindles etc. Perhaps this carefull setting is not really neccesary. For many years I was meticulous with ignition timing until I got an old kickstart sportster with manual advance and retard, once started it did'nt seem different wherever it was set!
Tom M Posted July 4, 2012 Posted July 4, 2012 On 7/3/2012 at 7:04 AM, moto fugazzi said: Thanks! The only question I have is: how do I verify the idle trim is set at zero? Not sure how to do that. Ken You can read the idle trim with VDST. I don't remember the menu path. You're supposed to be able to adjust the trim with VDST too but I couldn't figure out how to do it. My trim value was grayed out and I couldn't edit it. Fortunately I didn't need to because it was already set at 0. There's a forum for VDST at guzzitech.com. If you have a problem with it you may get a better response there rather than here.
Kiwi_Roy Posted July 4, 2012 Posted July 4, 2012 On 7/3/2012 at 9:31 PM, 68C said: If you were asking about my MyECU, I built it although not without problems, as posted on the MyECU forum, had it running for a few days when it quit. Probably my assembly quality. Have just built another one and am now trying to get that to run. The TPS flying leads I added are certainly handy, for a instance - I rode around with the stock ECU and a multimeter reading the TPS voltage strapped to the tank, on the over run with a closed throttle it does not always go to the same setting as a cold stationary engine. I think it must be vacuum taking up the slack in the mechanical parts of the butterfly spindles etc. Perhaps this carefull setting is not really neccesary. For many years I was meticulous with ignition timing until I got an old kickstart sportster with manual advance and retard, once started it did'nt seem different wherever it was set! I found the same thing, TPS would not always go to the same place or Idle at the same speed. I put this down to slop in the linkage So in spite of what others say I used the right throttle stop as well, now it always goes to the same mV and idles more consistent.
