Paulsmartv11 Posted February 29, 2012 Posted February 29, 2012 the drive shaft is bolted to transmission housing by 2 allen screws, they were bolted up very tight when I unscrewed them, what is the torque for tightening up? Paul
Kiwi_Roy Posted February 29, 2012 Posted February 29, 2012 I don't know if theres a setting but the bolts are pretty tough, I just tighten mine up as tight as I can using a short handle allen key. It's such a solid arrangement I don't think anything would happen if the bolts were left loose i.e. just nipped up. BTW, be carefull to line up the indent in the shaft with the holes in the coupling otherwise it's very easy to spoil the thread of the bolts. Don't forget to line up the paint marks on the shaft if you pull apart the splines. Roy
nuevototem Posted February 29, 2012 Posted February 29, 2012 Hi, is hard because for security it use loctite... dont remember witch one. Best regards
