I do believe the neutral switch can be changed without removing the side plate of the gearbox, only the starter.
Again, some have found joy cleaning them with a solvent while working the switch in and out and, also, changing gear oils (to Redline as I recall.)
Otherwise, fitting a new neutral switch is no big deal and pretty common. Make sure the middle relay or its contacts aren't also dodgy.
+1 on keeping the sidestand switch. Cleaning it with some contact cleaner while working it in and out and forcing a bit of dielectric grease around the actuator keeps them reliable. Make sure the adjustable bolt that presses the actuator comes in good contact and is not bent.
I actually removed mine last night without removing the starter. I just didn't have any replacement gear lube so I screwed it back in. I have a new switch on order and I'll change out the lube to Redline Shockproof when it gets here.
So today I took the switch out and drained the gearbox. I cleaned the switch with some WD40 and worked it back and forth. Still didn't work. Reassembled everything and filled the box with Redline Shockproof. Went for a 30 mile ride and when I got home and put the bike in neutral the light came on. Go figure... :huh2:
I have a new switch on order but if this keeps working I'll save the switch as a back-up.
Which Redline did you go with, strawberry (heavy) or blueberry (light)?
The red. So far so good. The switch worked all day today.
