luther61 Posted March 20, 2012 Posted March 20, 2012 hi there,if i fit straight threw termi,s do i need to upgrade ecu chip,v11 scura.will it cause engine damage if not chipped,,,many thanks luther
Tom M Posted March 21, 2012 Posted March 21, 2012 You won't damage your engine by running aftermarket exhaust with your stock ECU. If you open up the intake too it might run a little lean at which point you might want to consider either setting your TPS a little higher or add a PCIII or similar device. There are no "chips" available for the V11 ECU.
Guzzirider Posted March 21, 2012 Posted March 21, 2012 You wont damage your motor but it is worth investing in getting your fuelling set up properly if you are splashing out on Termignonis. Use the search function and you will find plenty of info re ways of tweaking your ECU.
