mismatched bulb wattage,blown bulb,bad earth, but if both sides my moneys on a dud flashercan
Relay is engaging but not releasing.
Capacitgor inside the relay may be burned out. Could be the transistor too.
Wrong bulb usually makes it go faster by changing the load, but doesn't freeze it.
Personally, I would try replacing the relay first.
As others have said, if both front and rear lamps are on (assuming you haven't just replaced the lamps with LEDs it's likely the flasher can.
I think LEDs use a different electronic flasher with 3 terminals, the 3rd one grounded to the chassis.
