df2 Posted May 12, 2012 Posted May 12, 2012 Okay so I thought I'd get cute and change my oil by using the port hole. Even spent 20 bucks on the tool. Everything goes great until I try to actually get the filter off. Filter wrench just wont fit on it right. No room to get any other tool or your hand on the filter....why make it nearly the same diameter as the filter? so now i just want to put it back together and do the filter next time. Can't get the porthole back on, keep cross threading it, try again and again.... So finally pull the sump. So easy. I can get the porthole to lay flat and thread, Plus I get to really clean it out. Easy to change filter...Moral, just pull the sump. 1
felix42o Posted May 13, 2012 Posted May 13, 2012 On 5/12/2012 at 10:11 PM, df2 said: Okay so I thought I'd get cute and change my oil by using the port hole. Even spent 20 bucks on the tool. Everything goes great until I try to actually get the filter off. Filter wrench just wont fit on it right. No room to get any other tool or your hand on the filter....why make it nearly the same diameter as the filter? so now i just want to put it back together and do the filter next time. Can't get the porthole back on, keep cross threading it, try again and again.... So finally pull the sump. So easy. I can get the porthole to lay flat and thread, Plus I get to really clean it out. Easy to change filter...Moral, just pull the sump. Sorry you found out the hard way, but at least you didn't bugger the threads on the manhole cover. Glad you got it figured out.
AndyH Posted May 15, 2012 Posted May 15, 2012 On 5/14/2012 at 12:29 PM, fotoguzzi said: did you hose clamp the filter? do a search.. When they say hose-clamp the filter, hose-clamp the filter! Glad I found out when I did: the filter cartridge fitting apparently has two modes: welded on tight or spin-off loose. The latter will lose oil pressure... Do you want to take a chance? AndyH
df2 Posted May 18, 2012 Author Posted May 18, 2012 On 5/15/2012 at 7:52 PM, AndyH said: On 5/14/2012 at 12:29 PM, fotoguzzi said: did you hose clamp the filter? do a search.. When they say hose-clamp the filter, hose-clamp the filter! Glad I found out when I did: the filter cartridge fitting apparently has two modes: welded on tight or spin-off loose. The latter will lose oil pressure... Do you want to take a chance? AndyH Okay, so yes I know all about the hose clamp....what I don't know or can't find is the application of it. Anybody have the instructions? Does it just go on anywhere, in any direction?
grossohc Posted May 18, 2012 Posted May 18, 2012 Put the hose clamp onto the filter beside a oil pipe so if the filter wanted to back off the screw on the clamp hits the pipe and stops it from turning. (hope this makes sense).
df2 Posted May 18, 2012 Author Posted May 18, 2012 On 5/18/2012 at 6:59 PM, grossohc said: Put the hose clamp onto the filter beside a oil pipe so if the filter wanted to back off the screw on the clamp hits the pipe and stops it from turning. (hope this makes sense). Total sense. Thanks
