I like to spray brake clean on a rag and use that to wipe it off. The brake clean does a better job of cleaning the tube and spraying it on a rag instead of the tube allows you to control where it goes.
It could be the seal grease from what you said, I would give it more time with cleaning. Maybe you should talk to the guy that replaced the seals to get his opinion.
You could also pull the wiper ( that first outer part of the seal that you can see, that actual seal is deeper inside) and see what is under there. If it is fork oil it would likely be wet under there, if it is grease it will just be..... well, greasy. Just be careful.
Easily done, I'll check it out.
AndyH
