Guest Steve in VA Posted December 13, 2003 Posted December 13, 2003 I just bought a 2000 V11S w/ a PC III. it has a map which was made for it, but not dyno'd. I woudl like to find some other maps to try, because it is winter and I can not ride that much. Where can I find custom shared maps?
twhitaker Posted December 13, 2003 Posted December 13, 2003 Todd Egan at www.guzzitech.com is the maestro og custom maps for the PCIII.
twhitaker Posted December 13, 2003 Posted December 13, 2003 You didn't happen to get your bike from Rich Maund, did you? If that's the case, you can trust it to be completely optimized. You lucky devil.
Guest dkgross Posted December 13, 2003 Posted December 13, 2003 I'll second that. If indeed you are the owner of Rich's bike, welcome to our little group, and take comfort in knowing that you probably are riding the most cared for, most loved Guzzi ever made.
al_roethlisberger Posted December 13, 2003 Posted December 13, 2003 www.guzzitech.com mailto:todd@guzzitech.com Todd is the resident PCIII/Guzzi guru and works directly with Dynojet developing PCIII solutions for Guzzis. He is also on this board frequently and may chime-in on this thread. ...choose the map that best fits the modifications on the bike. Be careful not to randomly pick a map that doesn't fit your configuration, as you wouldn't want to overly lean out the fuel. And yes, if you've got Rich's bike... congratulations! It's probably already got the best map possible short of an actual Dyno run as Todd provided that map for Rich. al
