Kiwi_Roy Posted June 18, 2012 Posted June 18, 2012 I decided to change the timing chain and tensioner, I purchased one from MG Cycle When I pulled the old one out it's hard to see how the new one will fit in its place. Can anyone please confirm if is right or wrong. Thanks Roy Old one at the top New one at the bottom
AndyH Posted June 18, 2012 Posted June 18, 2012 On 6/18/2012 at 5:07 AM, Kiwi_Roy said: I decided to change the timing chain and tensioner, I purchased one from MG Cycle When I pulled the old one out it's hard to see how the new one will fit in its place. Can anyone please confirm if is right or wrong. Thanks Roy Old one at the top New one at the bottom I was wondering about how that fitted too, so I held off getting one. Would be interested to hear the answer. Andy
Admin Jaap Posted June 18, 2012 Posted June 18, 2012 Fitted one in my Centauro engine. Fits w/o problems and works too as far as I can see. Not tested yet, but if they wouldn't work right, I dont think they'd be still up for sale. Here's a pic (not mine btw)
Kiwi_Roy Posted June 18, 2012 Author Posted June 18, 2012 On 6/18/2012 at 9:29 AM, Admin Jaap said: Fitted one in my Centauro engine. Fits w/o problems and works too as far as I can see. Not tested yet, but if they wouldn't work right, I dont think they'd be still up for sale. Here's a pic (not mine btw) Thanks Jaap, I was worried perhaps the tensioner was intended for a different engine. On first sight the original looked OK but I was able to push it to the case and it would sometimes stay there. All I have to do now is figure out how to get the nut off the crankshaft Update, A 3/4" drive 32mm socket fits over the shaft. I ground a couple of flats on it and spun it off with a 12" Crescent wrench. Wrap a couple of turns of masking tape over the shaft to protect it. What was I doing wrong there?
AndyH Posted June 18, 2012 Posted June 18, 2012 On 6/18/2012 at 9:29 AM, Admin Jaap said: Fitted one in my Centauro engine. Fits w/o problems and works too as far as I can see. Not tested yet, but if they wouldn't work right, I dont think they'd be still up for sale. Here's a pic (not mine btw) You wouldn't think there was room if it wasn't there in technicolor! I was thinking this would be a sensible mod for a road rider like me, but how does this compare to a timing gear set:, has anyone tried them? Spur vs straight cut, steel vs alloy etc etc.? So many options... they're expensive but are they worth it to anyone not racing or outright performance hungry? Andy
Kiwi_Roy Posted June 20, 2012 Author Posted June 20, 2012 All back together. No - I didn't jamb a brass drift in the chain to tighten the nuts, I did to remove them because I was replacing the chain anyway. To tighten I put the bike in top gear and foot on the brake. I can't believe how crude the OEM tensioner is compared to the one from MG Cycle. Hopefully it will cure the sneeze Because the original bolts are too long to simply screw back in without the bracket I hacked it off and scratched on a message for the next caretaker Many thanks to Carl for pointing to the upgrade and Jaap for the picture of one installed Roy
Slavomir Musilek (R.I.P.) Posted June 20, 2012 Posted June 20, 2012 this change is worth every penny spent
luhbo Posted June 28, 2012 Posted June 28, 2012 On 6/20/2012 at 4:51 PM, Kiwi_Roy said: All back together.... Roy Roy, what are your experiencies? Do you like the new tensioner? Everything as smooth as before? Hubert
Cabernet Posted June 28, 2012 Posted June 28, 2012 On 6/20/2012 at 6:16 PM, Slavomir Musilek said: this change is worth every penny spent Why? Is this an upgrade for all models or certain years? Thanks
luhbo Posted June 28, 2012 Posted June 28, 2012 Yep. Fits for all big 2 valvers. It's cheaper than the original one, but I see definitely no need to open the engine just for exchanging a good tensioner with another one. Hubert
pete roper Posted June 28, 2012 Posted June 28, 2012 On 6/28/2012 at 8:44 PM, luhbo said: Yep. Fits for all big 2 valvers. It's cheaper than the original one, but I see definitely no need to open the engine just for exchanging a good tensioner with another one. Hubert Agreed. The stock tensioner in the later models works fine and seems to last well. The Valtech 'Blade' type shown is IMHO a better device but care has to be taken when installing it. Make sure that the spring doesn't run across the timing cover screw boss or the cover will leak and be careful when installing the blade which is more easily done AFTER the chain and sprockets have been re-installed. The Valtecs *can* be noisy at first but it usually settles down within a few hundred kms. Discussing timing gears always brings nutters out of the woodwork. Theoretically gears are a better option. In reality it is unlikely that on a road bike anybody would notice any benefit. If you do choose to go down this route though I strongly advise against any type of aluminium or aluminium/steel combination sets. I've just seen too many fail and refuse to install them. There are steel sets available, there is a bloke in the UK I think, who makes straight cut steel sets but the are very spendy. There used to be helically cut steel sets available too a long time ago. While the helix allows you to play very precisely with the timing it does impose an end thrust on the shafts so you can expect greater cam thrust piece wear than you get with a chain or straight cut gears. Pete
Kiwi_Roy Posted June 29, 2012 Author Posted June 29, 2012 On 6/28/2012 at 10:39 AM, luhbo said: On 6/20/2012 at 4:51 PM, Kiwi_Roy said: All back together.... Roy Roy, what are your experiencies? Do you like the new tensioner? Everything as smooth as before? Hubert I can't say I notice much difference, the new tensioner certainly looks like it's going to do a better job. I know I will never have to do the chain again, and the oil pump gears look fine. The bike runs really well but has an annoying habit of skipping a spark every few seconds at idle, I proved this with a timing light. I thought it may have been timing chain slop, so that's one more thing eliminated.
Cabernet Posted June 29, 2012 Posted June 29, 2012 I will leave my 2003 (which may be a 2002) alone then. Thanks guys
docc Posted June 29, 2012 Posted June 29, 2012 On 6/29/2012 at 10:31 AM, Kiwi_Roy said: The bike runs really well but has an annoying habit of skipping a spark every few seconds at idle, I proved this with a timing light. I thought it may have been timing chain slop, so that's one more thing eliminated. Roy, Have you pulled the coil wires from the coils to inspect? I had one all green and nasty with the contact corroded in two. It kind of rides in the weather there.
