veloguzzi Posted August 2, 2012 Posted August 2, 2012 Has anyone replaced the screws that secure the TPS to the right throttle body assembly? Mine are full of yellow paint, too shallow to securely fit a proper hex tool, and can only be turned with a small vice grips. I need to replace them. If anyone has a source, I'd appreciate it. Thanks
docc Posted August 2, 2012 Posted August 2, 2012 They are actually not hex but Torx and it is a good move to replace them with hex fasteners making them so much easier to fettle with a simple 90 degree angled hex tool. The yellow paint is there to help you find the things that need messing with.
gstallons Posted August 2, 2012 Posted August 2, 2012 you could use a dental pick to remove the paint or remove one screw and go get replacements. Change them one at a time to keep the TPS in it's proper place. Docc, I like the reason for the paint code!
veloguzzi Posted August 3, 2012 Author Posted August 3, 2012 On 8/2/2012 at 11:23 PM, gstallons said: you could use a dental pick to remove the paint or remove one screw and go get replacements. Change them one at a time to keep the TPS in it's proper place. Docc, I like the reason for the paint code! Thanks I picked as much of the paint off as I could, still could swear those are hex heads. They will be shortly...
