thebronze Posted August 13, 2012 Share Posted August 13, 2012 I've got a pretty nice little oil leak. It seems to cover both sides of the block and looks like its coming from the base gaskets. We've chased it up to where the oil feed pipe comes out of the block and goes up to each cylinder. Has anyone had this cause a leak before? I've read about the engine paint preventing a good seal at this junction. I guess its possible the hose has split too. So before I plunk down $140 for the parts, has anyone done this before? What needs to come off the bike to get my hands in there? Its really in a tight spot. For sure the tank needs to come off and maybe the air filters and intakes, not sure what else at this stage. Thanks, Toby Link to comment Share on other sites More sharing options...
grossohc Posted August 13, 2012 Share Posted August 13, 2012 Yes, take off the tank and air filter housing, easy access to the lines after that. Link to comment Share on other sites More sharing options...
Guzzirider Posted August 13, 2012 Share Posted August 13, 2012 I have just done the job on my Quota which has an identical arrangement. New stainless hoses should be less than £40 including a new banjo bolt and crush washers! Link to comment Share on other sites More sharing options...
thebronze Posted August 13, 2012 Author Share Posted August 13, 2012 I have just done the job on my Quota which has an identical arrangement. New stainless hoses should be less than £40 including a new banjo bolt and crush washers! Hey, where are you finding the hose that cheap? The factory part is 106.73$ Is it 2 hoses or 1 Y shaped hose? Link to comment Share on other sites More sharing options...
Guzzirider Posted August 13, 2012 Share Posted August 13, 2012 Bought a pattern part made by my local spares supplier Gutsibits. It is two hoses joined together into one. Link to comment Share on other sites More sharing options...
thebronze Posted August 29, 2012 Author Share Posted August 29, 2012 Replaced the hose, she still leaks. Looks like its coming from the very top of the block behind the oil cooler. There's a couple sensors there that are leaking. Oil pressure and TDC maybe. I'll try to find the gaskets. Link to comment Share on other sites More sharing options...
Mike Stewart Posted September 2, 2012 Share Posted September 2, 2012 Hello, It would be best if you could clean off the top of the engine and then run the bike in the garage so you can maybe see if it is the braided line or just the crush washers at the center fiting. Also check the large breather hoses coming off of the frame as the V11 uses the frame for collecting the crank case fumes in that area. I have heard of oil leaks in this area which turned out to be a damaged piston causing big time blow by, hopefully this is not the case. Good luck, Mike I've got a pretty nice little oil leak. It seems to cover both sides of the block and looks like its coming from the base gaskets. We've chased it up to where the oil feed pipe comes out of the block and goes up to each cylinder. Has anyone had this cause a leak before? I've read about the engine paint preventing a good seal at this junction. I guess its possible the hose has split too. So before I plunk down $140 for the parts, has anyone done this before? What needs to come off the bike to get my hands in there? Its really in a tight spot. For sure the tank needs to come off and maybe the air filters and intakes, not sure what else at this stage. Thanks, Toby Link to comment Share on other sites More sharing options...
