dagersh Posted August 29, 2012 Share Posted August 29, 2012 Hi Guys, I just changed oil and filters on my '03 Rosso Corsa. Everything went smooth, the bike is holding its oil, and the level is perfect read with the dip stick screwed in and the bike is vertical on my work stand. Filter is a UFI, and is nice and tight. Oil is Rotella T 15-40. My oil light is on until 2,500 RPM any higher and all is well.... Did I muck something up? Gersh Link to comment Share on other sites More sharing options...
docc Posted August 29, 2012 Share Posted August 29, 2012 Old oil filter gasket definitely came off with the old oil filter? Link to comment Share on other sites More sharing options...
Tom M Posted August 29, 2012 Share Posted August 29, 2012 Don't run your engine! Drain the oil (save for reuse) and pull the filter cover off the bottom of the oil sump. Chances are real good that you filter is loose. Link to comment Share on other sites More sharing options...
mznyc Posted August 29, 2012 Share Posted August 29, 2012 Old oil filter gasket definitely came off with the old oil filter? Docc thank you I read this after just getting back from the garage after changing the oil.Made me get ta thinkin',as y'all tend to say.I went back to finish up some work and low and behold the old filter has lost it's o-ring.I'll bet the pink slip it's in the sump. Thank ya, thank ya, thank ya,... Link to comment Share on other sites More sharing options...
helicopterjim R.I.P. Posted August 29, 2012 Share Posted August 29, 2012 LIKE THEY SAID - PARK IT! FIX IT! Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 Guys, Thanks for the quick responses! Have not been running the engine other than to confirm the RPM where the light comes on/goes off, and even then did not let the bike warm up. I will check the old filter - still draining on my pan - so that should be easy enough. The new filter is defintely well beyond hand tight, I used the UFI Specific Filter Wrench with no problems, and I greased up the new seal and threads with clean oil. I will update when I get back to the garage. Thanks again!!!!! Gersh Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 Ok, Took a look at the old filter, it looks like the gasket is still on the bike. I am draining the sump now, and will pull the new filter and make sure that the old filter gasket is not still in there. Thanks again for everyone's responses! I will update after its all back together and running! Gersh Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 Alright... I have no idea where the old gasket is. Its not in my drain pan, not in the oil pan, and not on the gasket surface. Weird. I checked the gasket mating surfaceon the bike, nice shiney and clean. I then reinstalled the oil filter and made it very tight using the UFI specific wrench. I am going to put her back together and refill her with oil and see what happens. Wish me luck! Gersh Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 Whew - found the old gasket! My fishing expeditions in the drain pain did not reveal it, but as I was pouring the oil back into the conatainer - through a filter for good measure - there it was. OK - now to fill her up and see what is to see... Gersh Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 Whew - found the old gasket! My fishing expeditions in the drain pain did not reveal it, but as I was pouring the oil back into the conatainer - through a filter for good measure - there it was. OK - now to fill her up and see what is to see... Gersh Success!!!!!!! Thank you, thank you, thank you!!!!!!!!!! Gersh Link to comment Share on other sites More sharing options...
luhbo Posted August 29, 2012 Share Posted August 29, 2012 You could as well put it back into the sump again, and two more if you like. What was the reason for the retarded oil light? Have you found it, too? Hubert Link to comment Share on other sites More sharing options...
dagersh Posted August 29, 2012 Author Share Posted August 29, 2012 You could as well put it back into the sump again, and two more if you like. What was the reason for the retarded oil light? Have you found it, too? Hubert Luhbo, I accidentally left the old gasket in place when I removed the old filter. Did not realize it, so the new filter had double gaskets. At 2500 RPM, the pump was strong enough to push enough oil to satify the oil light sensor. Problem solved, just took her for a run, and all is well! Gersh Link to comment Share on other sites More sharing options...
mznyc Posted August 30, 2012 Share Posted August 30, 2012 Found mine stuck to new filter,what timing. Id rather be lucky than good. Link to comment Share on other sites More sharing options...
dagersh Posted August 30, 2012 Author Share Posted August 30, 2012 Found mine stuck to new filter,what timing. Id rather be lucky than good. MZ - YOu in NYC? Link to comment Share on other sites More sharing options...
mznyc Posted August 30, 2012 Share Posted August 30, 2012 Found mine stuck to new filter,what timing. Id rather be lucky than good. MZ - YOu in NYC? Yup,bikes I leave up near New Paltz/Woodstock Link to comment Share on other sites More sharing options...
