Admin Jaap Posted September 30, 2012 Posted September 30, 2012 Asked this question in the other reaction rod topic, but it got a little lost there... Could someone please measure the heart to hearth length between both holes? The one in the picture below is from a 1100 sport. Is it the same on a V11?
rich46 Posted September 30, 2012 Posted September 30, 2012 Mine measured 355.6 mm bolt center to bolt center. Rich
Skeeve Posted October 4, 2012 Posted October 4, 2012 Asked this question in the other reaction rod topic, but it got a little lost there... Could someone please measure the heart to hearth length between both holes? The one in the picture below is from a 1100 sport. Is it the same on a V11? I doubt it: the 5spd 1100 Spot/Sporti had a different shaft/swingarm length than the later V11 w/ its 6spd box. [Part of the reason Guzzi redesigned the box & went with the unusual design was to get a longer shaft length to reduce the angle on the U-joint and move it outboard so wider tires could be fitted.]
Admin Jaap Posted October 4, 2012 Author Posted October 4, 2012 As you can see in the attached picture above the 1100 Sport rod is +/- 407 mm length, so you're right.
