motowarren Posted October 7, 2012 Posted October 7, 2012 When I go to downshift sometimes it seems like the trans can't decide whether it wants to shift or not. Sometimes it just finds a false neutral and sometimes it goes down a gear but with a very slow meshing sound and finally finds the gear. This is obviously very disconcerting when running fast over back roads when you need it to be precise to go through a pretty fast turn. Does this have anything to do with the park pawl/spring or is it something else?
luhbo Posted October 7, 2012 Posted October 7, 2012 Shifting lever not touching the sideplate? Moving freely, not sticky? Not too much play? The spring is a binary thing. Hubert
mznyc Posted October 7, 2012 Posted October 7, 2012 How many miles on it? Do you know if the friction plates have ever been replaced? What you can check on the outside, Linkage working and not touching the porkchop on the down shift and sub frame on the upshift. Put bike on rear stand,put in gear and pull clutch while turning rear wheel.Wheel should move freely.I have long arms but if you dont get a friend to help you. If those are OK,you'll have to look at the pre=selector assembly.Not a big deal,shouldnt take that long.Disconnect battery,free shock remote,disconnect leads to starter,remove starter,shift linkage,11 screws on the cover and she's off.
gstallons Posted October 7, 2012 Posted October 7, 2012 You do have the proper fluid and proper amount of fluid in the transmission ?
motowarren Posted October 7, 2012 Author Posted October 7, 2012 The bike has 43k miles on it. The fluid is at the level it should be but I have no idea what brand/weight fluid is in it. The bike has Motobits foot controls and nothing is binding. As far as the clutch dragging I'll have to wait for a friend to help me check that. The clutch does seem inconsistent sometimes as to the speed in which it engages, Seems like slow hydraulics. As for inside the box I have no idea what it looks like or what I should be looking for when I get in there. I plan on doing that in the next month or so and doing the recontouring of where the spring rest but I'm not sure what else to do in there.
mznyc Posted October 8, 2012 Posted October 8, 2012 With those symptoms and mileage ,it could be the friction plates.Try all the exterior stuff,flush/ bleed clutch fluid and see what you get.No fluid in the clutch housing? Pull timing hole cover and look inside with a flashlight there should be no fluid in there
Bjor Posted October 8, 2012 Posted October 8, 2012 Could it be as simple as lack of grease on the pivot bolt of the shifter lever...?
motowarren Posted October 25, 2012 Author Posted October 25, 2012 Well I fixed my shifting problem today. simply changed the oil to the Red Line heavy shock proof oil. I have never had a lubricant of any sort make that much difference in anything. I just got back from a 200 mile ride. All back roads with about 50 miles of long sweepers and 35 miles of intense mountain twistys and I didn't miss one shift. It felt like a new gearbox. So I'm satisfied with that problem being fixed...at least for now. Now the only thing left to fix is the gas mileage problem. That will have to wait for a while 'til I get some funds together for "My ECU" so I can run a closed loop system. The 200 mile ride was great. 74 degree beautiful sunny day and the leaves here in PA are at their peak fall colors and the Guzzi ran great and I felt as one with the bike. The more I ride this thing the better I like it.
gstallons Posted October 25, 2012 Posted October 25, 2012 What type of fluid were you using in the gearbox ?
motowarren Posted October 25, 2012 Author Posted October 25, 2012 What type of fluid were you using in the gearbox ? I don't know. Fluid that was in was from PO. It was very dark with a red tint.
Kiwi_Roy Posted October 25, 2012 Posted October 25, 2012 It's amazing that new oil can make such a difference. What's the explanation for that?
Gio Posted October 25, 2012 Posted October 25, 2012 It's amazing that new oil can make such a difference. What's the explanation for that? No idea Roy - but Shockproof heavy seems to make a difference in the way our boxes work. I'm a believer ... in fact I'm trying to source some here on the east coast (to no avail) in preparation for some winter service work ( I change it every 20k even though I'm told it should not be necessary to) ..? Gio
DSRDAVE Posted October 26, 2012 Posted October 26, 2012 It's amazing that new oil can make such a difference. What's the explanation for that? No idea Roy - but Shockproof heavy seems to make a difference in the way our boxes work. I'm a believer ... in fact I'm trying to source some here on the east coast (to no avail) in preparation for some winter service work ( I change it every 20k even though I'm told it should not be necessary to) ..? Gio The Red line oils are used a lot in road racing of cars. You can try sources such as Pegasus racing and others for it.
Chuck Posted October 26, 2012 Posted October 26, 2012 I run the 80 wt.. http://www.racerpartswholesale.com/category/MotorcycleGearOil
Gio Posted October 27, 2012 Posted October 27, 2012 It's amazing that new oil can make such a difference. What's the explanation for that? No idea Roy - but Shockproof heavy seems to make a difference in the way our boxes work. I'm a believer ... in fact I'm trying to source some here on the east coast (to no avail) in preparation for some winter service work ( I change it every 20k even though I'm told it should not be necessary to) ..? Gio The Red line oils are used a lot in road racing of cars. You can try sources such as Pegasus racing and others for it. Thanks Dave - but I'm on the east coast of Canada and can not find ANY dealers ..? Might have to ask Kiwi Roy to post me a bottle from the west coast (available from Mopac ... what do you say Roy?) or just order on-line. Gio
