X goose Posted June 20, 2021 Posted June 20, 2021 Hello, Has anyone been able to load Guzzidiag to a Mac running Big Sur? I can't get it to go
hammershaug Posted June 20, 2021 Posted June 20, 2021 16 hours ago, X goose said: Hello, Has anyone been able to load Guzzidiag to a Mac running Big Sur? I can't get it to go Sorry, Guzzidiag won’t open with newer versions of macOS I am afraid. Easiest route is to install Windows 10 Pro on the Mac from Bootcamp. Very simple and free. See my last post. 1
X goose Posted June 23, 2021 Posted June 23, 2021 Thanks Hammershaug I am going to try and kill two birds I guess. I need the OS that will run both Guzzidiag and Tune ECU for my KTM. I think the last time I connected to the KTM I was on win 8 but I suspect finding a driver and cable adapter for a current Mac will be challenging. I'll look into running that on win10 if that's what Guzzidiag prefers. It's this type of thing that makes me miss carburetors!! 2
docc Posted June 23, 2021 Posted June 23, 2021 17 minutes ago, X goose said: It's this type of thing that makes me miss carburetors!! More Black Arts! 1
68C Posted June 23, 2021 Posted June 23, 2021 Come off it docc, diaphragm? That's not even a real carb. God invented the flat slide for a reason 2
Pressureangle Posted July 4, 2021 Posted July 4, 2021 On 6/23/2021 at 7:37 AM, 68C said: Come off it docc, diaphragm? That's not even a real carb. God invented the flat slide for a reason Just think of the diaphragm as a *really* simple computer that interfaces the carb and the unpracticed throttle hand. 1 1
docc Posted August 11, 2023 Posted August 11, 2023 Will GuzziDiag load and run from a Samsung Galaxy A14 5G running Android version 13?
audiomick Posted August 11, 2023 Posted August 11, 2023 44 minutes ago, docc said: Android version 13? Quote from Bernd's documentation on the German forum: Quote Was benötigt man nun um mit dem Steuergerät sprechen zu können? 1. Ein Computer mit einem der folgenden Betriebssystemen Microsoft Windows (ab XP) sowohl 32 als auch 64bit Linux (ab Kernel 2.4) sowohl 32 als auch 64bit Apple Mac OS (ab Version 10.4) nur 64bit und nur auf Intel Basis DeepL says: Quote What do I need to be able to talk to the control unit? 1. a computer with one of the following operating systems Microsoft Windows (from XP) both 32 and 64bit Linux (from kernel 2.4) both 32 and 64bit Apple Mac OS (from version 10.4) only 64bit and only Intel based So, no, it wont. 1
docc Posted August 12, 2023 Posted August 12, 2023 At one of our South'n SpineRaids, an experienced technician used a "tablet" (or something like that) to connect GuzziDiag. I was impressed with the handiness! I was given this Samsung/Android "SmartPhone" as a SatNav tool since I complain bitterly, and endlessly, about my Garmin experiences. Not sure where my SatNav is going, but that is another topic . . . What would be the smallest, most reliable "handheld" device to connect GuzziDiag in a remote setting?
audiomick Posted August 12, 2023 Posted August 12, 2023 We have a thing at work called a "surface". I believe it is a Microsoft product. Runs windows, and is effectively a normal Windows PC, but in the "tablet with touchscreen" form. I'd be looking for something like that. I have no real idea if the operating system on an i-Pad is the same as in a Mac computer, but believe it is not (i.e. Guzzidiag wouldn't run). 1
80CX100 Posted August 15, 2023 Posted August 15, 2023 On 8/11/2023 at 8:02 PM, docc said: At one of our South'n SpineRaids, an experienced technician used a "tablet" (or something like that) to connect GuzziDiag. . . . What would be the smallest, most reliable "handheld" device to connect GuzziDiag in a remote setting? Hey Docc, I've also read of experienced techs using GD on smaller/simpler tablet devices,,, the fine working details are above my paygrade. I know this isn't your first rodeo,preaching to the choir I'm sure;but for the benefit of others that might be reading; depending on how remote a setting you'll be at,,, electrical power supply/chargers to keep bikes & devices,charged & working right for repeated use,is also something to keep in mind. fwiw 1
