Tom M Posted March 20, 2013 Posted March 20, 2013 I have Conti Road Attacks on mine. Love the way it handles with them. Prior to that, Diablo Strada rear and Diablo Sport front. Ok, but not as confidence inspiring as the Contis. I really liked the way my bike handled with the Road Attacks but they only lasted about 4k miles for me. I see that Conti now has a Road Attack GT that's supposed to last longer. I'll probably give them a try when I wear out the Michelins that I have now.
GuzziMoto Posted March 21, 2013 Posted March 21, 2013 For my 2x V11: #1: V11 KS LeMans Tenni built 2002 ** Rim: front: Brembo Aluminium 3,5 x 17" rear: Brembo Aluminium 5,5 x 17" ** Tyre size: front: 120/70 ZR17 M/C 58W rear: 180/55 ZR17 M/C 73W ** Tyre types: before = Michelin Pilot Road 2 now = ContiRoadAttack2 =================================== #2: V11 KR Sport built 2001 ** Rim: front: Brembo Aluminium 3,5 x 17" rear: Brembo Aluminium 4,5 x 17" ** Tire size: front: 120/70 ZR 17" M/C 58W rear: 170/55 ZR 17" M/C 72W ** Tyre types: now: ContiForce -M- You may want to try a 160 on the 4.5" rim for the 2001. Most 170's are made for a 5" rim and get pinched when installed on a 4.5" rim. Plus the 160 is lighter.
dangerous Posted March 21, 2013 Posted March 21, 2013 its all in the head... these days a tyre is a tyre, that is why I wear metzler
Chuck Posted March 21, 2013 Posted March 21, 2013 its all in the head... these days a tyre is a tyre, that is why I wear metzler YMMV.
dangerous Posted March 21, 2013 Posted March 21, 2013 Huh ? yeah... I have no idea what Chuck said either? what I said is a black rubber ring is a black rubber ring, all the brands named are black rubber rings all as good as each other (cos no one has mentioned chang chin or similer) so its in the head as to wht you ride on, and that is why I ride on Metzler... cos my head is happier, not cos they are any better than the next tyre. So to answer the opening poster, put what you are most comfortable with on and ride that farking thing.
LowRyter Posted March 22, 2013 Posted March 22, 2013 YMMV Your Mileage Might Vary I need a new rear. That Qualifier is down to the wear bars. Planning to ride to Austin TX and Jasper Ark in a 3 weeks, it'll have to be replaced before I travel. The front Angel looks good. Think I'll get an Angel. The tire didn't last through an oil change. I'd guess I put 3500 miles on it. 1
Kiwi_Roy Posted March 26, 2013 Posted March 26, 2013 PS. Be sure to actually check the rim for width and not base it on the published specs. Guzzi had a habit of using the parts they had on hand whether they were the right ones or not. This got me thinking, where do you measure the rim, inside the bead or outside or is the measurement taken across the tire?
GuzziMoto Posted March 26, 2013 Posted March 26, 2013 The measurement would be inside the rim, but it should be easy enough to read what is stamped on the rim. DOT standards require a rim to be permanently stamped with its dimensions.
docc Posted March 26, 2013 Posted March 26, 2013 The measurement would be inside the rim, but it should be easy enough to read what is stamped on the rim. DOT standards require a rim to be permanently stamped with its dimensions. And there it is on one of the spokes, left side: "mt4.50x17dot e." Learn something here everyday! Otherwise, pulling a tape across shows an outside measurement at the corner of the rim of about 5". I suspect the 5.5 would look about 6" at the outside edges.
LowRyter Posted March 29, 2013 Posted March 29, 2013 I tried to find 170/60 Pirelli Angel GT today and seem they are hard to find.
LowRyter Posted March 31, 2013 Posted March 31, 2013 I am going with Michelin Pilot Road 3 as a replacement rear for the Dunlop Qualifier I have on now.
Gio Posted April 1, 2013 Posted April 1, 2013 LowRyter - I also had no luck in sourcing a 170/60 Angel GT ... seems they are not generally available as yet, but plan to go this way at next change. Gio
docc Posted April 1, 2013 Posted April 1, 2013 Looks like Motorcycle Superstore has both the 170 and the 160 "in stock" in the Pirelli Angel ST and the 160 "available" in the GT. When the Angel ST came out, I found it gave me the exact same mileages as the Diablo Strada before it . I'm on my 23rd rear tire: nine Pirellis as well as Dunlop, Bridgestone, Michelin, and Metzler. I would say they have not all been the same.
