bikelee Posted April 12, 2013 Posted April 12, 2013 I'm gonna go with the MPH handlebar risers and that requires clutch and brake line replacement. I have bled lines before but have not replaced any in a long time. Any tricks or techniques for doing this ? I have a Mity-vac but when I use it, air seems to get around the area where the clear tube attaches to the bleed nipple even though the tube seems to fit real tight. I put a little thick grease on the threads of the nipple and that seems to stop air from getting in that way. Also should I remove the rear wheel to gain better access to the clutch bleed nipple ? I have kinda big hands. Thanks for any help or suggestions !!
Tom M Posted April 12, 2013 Posted April 12, 2013 The only way that I can bleed the clutch is with the rear wheel out so I'd say that's your best bet. I put a few turns of teflon tape on the bleeder threads when I use the mityvac to prevent the air leakage there. My bike already had aftermarket front brake lines on it when I bought it so I can't say if there's anything tricky about removing the stock lines. It looks pretty straightforward in the parts diagram. Just don't get any fluid on the paint.
mznyc Posted April 12, 2013 Posted April 12, 2013 Wot Tom says + Very easy to strip the nut on the bleeder.Note post #21 here,.. http://www.v11lemans.com/forums/index.php?showtopic=16028&hl=mznyc&page=2
gstallons Posted April 13, 2013 Posted April 13, 2013 Use the Mighty-Vac with NO petroleum base grease anywhere around brake parts. The teflon tape (or liquid pipe thread sealant) is a smart idea too. remove the rear wheel and inspect rear wheel bearings n grease driveshaft
