sculler2x Posted June 4, 2013 Share Posted June 4, 2013 I replaced the high pressure fuel lines on my V11 and now I have a fuel leak and it is not the lines or clamps. When it is cool fuel comes out where the T fitting goes into the injector. Any ideas on how to stop this? Link to comment Share on other sites More sharing options...
docc Posted June 6, 2013 Share Posted June 6, 2013 Is there not an O-ring for that junction? is it both injectors? Link to comment Share on other sites More sharing options...
moto fugazzi Posted June 7, 2013 Share Posted June 7, 2013 There should be O rings at the T fittings. Your local NAPA should have them. It certainly isn't a picnic taking the injectors off. IIRC, there's a circlip that needs to be removed to remove the T fitting at the injector. If you're going to remove the injector for this, it wouldn't hurt to send them in for cleaning at that point. I sent mine to www.lindertech.com, and I think the total cost with shipping was around $80 for the pair. Did you use fuel injector clamps when replacing the hoses? They don't dig into the hoses like standard hose clamps do. Ken Link to comment Share on other sites More sharing options...
sculler2x Posted June 12, 2013 Author Share Posted June 12, 2013 It is only the left side and I used the injector clamps. The leak stopped for a while when it was warmer but it started again after 3 days of rain and cold. Link to comment Share on other sites More sharing options...
sculler2x Posted July 1, 2013 Author Share Posted July 1, 2013 The problem is now solved. I was able to remove the T fitting without removing the injector by releasing the circle clip. The O-ring was in perfect condition but it was not free to move. I have seen this before in industrial applications. I put fuelproof Flourinated (Krytox) grease on the O-ring and mating surfaces and the leak was stopped. http://www2.dupont.com/Lubricants/en_US/applications/O_rings.html Link to comment Share on other sites More sharing options...
