Bugtarget Posted June 26, 2013 Posted June 26, 2013 Hi All,Does anyone know if a FBF cross over is compatible with an after market Teo Lamers V11 Sport/LeMans center stand?Thanks!
Tom M Posted June 26, 2013 Posted June 26, 2013 I believe that Greg Field said that the Mistral is the only aftermarket crossover that works with the centerstand. If you search on his name and "centerstand" you should be able to find his thread on it. FWIW the FBF crossovers are notorious for cracking. I had stiffeners welded to mine before I installed and it still cracked after about 12k miles.
docc Posted June 26, 2013 Posted June 26, 2013 Here is the Greg Field thread with that specific info and his entire crossover comparison : A Tale of Four Crossovers
