Deos anyone know of someone who can repair the speedo of my V11?
Went out tonight for a short run and noticed the speedo has stopped recording millage, even the drip has stopped working!!
I'm guessing it still shows speed (needle still moderately accurate), right?
If so, it'll be the speedo itself and Casadimoto is good to do the work http://www.casadimoto.de/ but the site's in German and as my German is really poor, I sent my tacho to Stein Dinse and they handled the transaction with Casadimoto (and probably made a few quid out of it) but made the process really straightforward.
Otherwise, the 60deg drive at the gearbox end is probably the culprit: stripped nylon worm (nylon, I ask you!?). I have 3 junked drives in a box, so it's been a regular event. Replace the cable at the same time (it's the cheap bit), lube it well and give it the straightest run possible.
Thanks, yes it still gives a speed reading just the millage isnt beong clocked up...I'll give  CasaCasad
Casadimoto a try..
