Kiwi_Roy Posted August 23, 2013 Posted August 23, 2013 This idea went down like a lead balloon over on the other site I post Let see if it floats here The light will flicker or dim if you have a bouncing sidestand or bad switch contact.I prefer to use a 12 Volt LED for this, they are easy to see in bright sunlight if pointing in the general direction of your eyeThis is not intended as a permanent installation just string the wire across the tank to the fusebox.If you don't have an electric petcock wrap the wire around the relay pin.I haven't shown any detail of the ECU circuit because that wiring is very reliable.
docc Posted August 23, 2013 Posted August 23, 2013 Kiwi Roy gives us the best of the best electrical!
