I'm taking the rear wheel off of my 2003 LeMans Rossa to do a tire change. While I have the wheel off I'm gonna check the wheel bearings and the rear brake caliper pistons for crud on them. Anything else I should check ? Thanks !!
check the wheel bearings , inspect the brake pads and grease the driveshaft.
It really should have read "Rear End Maintenance" or "Things to do with the rear wheel off" as a title.Would make it easier to find,... :thumbsup:
grease DS but when you do the center zirk--- have the axle in place so it does not expand length of shaft or it's a bitch to get it back in when over full of grease.
Thanks Docc,I had thought it was easier to find in the past.
