gstallons Posted July 30, 2017 Posted July 30, 2017 NAPA Aviation form-a-gasket No.3 sealant part # B/K 765-1210
Chuck Posted July 31, 2017 Posted July 31, 2017 NAPA Aviation form-a-gasket No.3 sealant part # B/K 765-1210 I've been using that for about.. uhh.. 50 years.
docc Posted August 2, 2017 Author Posted August 2, 2017 Sweet! Eight leak sources in there: the two lower bolts. two flat gaskets, three shaft seals and the cam bung (I learned that term from a guy from "Bungendore", so I know it's for real! ). This is the best effort I could hope for. Thanks mightily to Andy York, Josh, and Goofman! (who all came over personally, but also to all the contributors making possible this basic tutorial on the leak sources in this area of the V11 Guzzi! )
docc Posted October 22, 2019 Author Posted October 22, 2019 On 8/2/2017 at 6:16 PM, docc said: Sweet! Eight leak sources in there: the two lower bolts. two flat gaskets, three shaft seals and the cam bung. This is the best effort I could hope for. Thanks mightily to Andy York, Josh, and Goofman! (who all came over personally, but also to all the contributors making possible this basic tutorial on the leak sources in this area of the V11 Guzzi! ) Over two years and ten thousand miles, this effort remains one of the best things I have ever done for my Sport. Thanks, again, to all that made it possible! On a little routine check-over I saw the vulnerable crankcase vent hose under the frame resting on, and abrading from, the oil supply lines for the heads at the front top of the engine block in the "V". A carefully placed Zip-tie and no hole will ever work through there . . . One of several updates to the Tank Off Maintenance Checklist . . . 2 1
