Clamped (hold) bar ends and twist-off hex bolt (I hope correctly understood the problem :whistle: )
So trying to remove the bar ends, probably never been off in 12 years! are they screw in? It just turns and turns!!! any ideas? thanks
http://www.stein-dinse.biz/images/product_images/popup_images/01600761.jpg
What keeps turning and turning is the grip shaft that the end weight threads into. So, yes, it unscrews, but you'll have to anchor the tube to unscrew the weight. Applying some heat to where they join might be helpful (after you cut off the left grip and remove the throttle pipe).  You might also get some penetrating oil to work into the threads at that same junction (the threads are all the way at the end of the tube).
