:oldgit: I need new brake pads for the front of my 03 Rossa. My left front fork seal got so bad I believe oil got on the pads. ( I'm in the process of repairing the seals now. I'm gonna replace the seals in BOTH forks even though only the left is leaking. I think it is just a matter of time till the right one starts leaking also. A mechanic I talked to at Kyle Racing said it is just good practice to fix both forks now. )Plus they are kinda worn anyways.  What part number do I need ! I'm a little confused. I guess I must be gettin' old. Thanks for any help. :mg::notworthy: Leon
I'm guessing you want a pad part number (pads should fit a range of euro bikes with brembo stoppers) however if you also need seals I had success via my Yamaha dealer, just rang them and asked for seals for a 2006 R1 LE. Saved me time and cash as Ducati & Guzzi dealers are thin on the ground down here.
Remove one of the pads and take it to the dealership . They can match them up for you .
