czakky Posted January 25, 2014 Author Posted January 25, 2014 okay, so the Loctite is used in place of a gasket where Hylomar is more of a dressing.
Dan M Posted January 27, 2014 Posted January 27, 2014 I just did this job. Mine started leaking a few years ago just before leaving on a weekend trip. The paper gasket was pushing out on the right side. I plucked out the piece of broken gasket and injected some silicone sealer in the gap. It lasted until this past summer. The replacement metal gasket should be the fix. Listen to Luhbo. Only use quality tools. Your days of rounding out fasteners will be over.
czakky Posted February 3, 2014 Author Posted February 3, 2014 Preliminary results might have been inconclusive.... Looks like my gasket might actually be holding! Which is good. But, Emry was pretty sure I had screwed up my first crank seal. Get two cranks seals. You have already screwed up the installed one, you might not get the first replacement, just... right... so that way you have another available while the process is fresh in your head. Saves you a bit of waiting for the mail. Took off the alternator cover after I've put around 300 miles and it doesn't seem to be leaking... Should I stop being lazy and just fix it? Or have the gods smiled on me and given me a pass?
gstallons Posted February 4, 2014 Posted February 4, 2014 It is not too lazy to run it a while to see..keep the parts where they can be found and be prepared..
emry Posted February 4, 2014 Posted February 4, 2014 If it isn't leaking don't touch it. No sense in tempting fate. When I nicked my seal doing the front cover the leak was quickly apparent. Didn't even have to ride it.
czakky Posted February 4, 2014 Author Posted February 4, 2014 I'll keep riding and check again in another 300 miles or so. After all a crank seal is peanuts compared to a new rotor/stator. Hence my paranoia.
czakky Posted March 17, 2014 Author Posted March 17, 2014 Now the seal has given up.... Oh well, I would have considered myself lucky if it didn't. She's gonna be apart again.....
czakky Posted March 28, 2014 Author Posted March 28, 2014 With a fresh seal it is possible to replace without removing the timing cover. Which only makes it slightly easier. But it's in.
docc Posted March 28, 2014 Posted March 28, 2014 With a fresh seal it is possible to replace without removing the timing cover. Which only makes it slightly easier. But it's in. This is the front crank seal behind the stator? How did you do t?
czakky Posted March 28, 2014 Author Posted March 28, 2014 Yessir, that seal. A 90 degree pick and side cutters. Glad to have it out too, because the thin spring looking ring from the lip of the seal had detached and could've wreaked havoc back there. I don't know if an old seal would have come out so easy but this one is a couple months and 1k or so miles old.
