So the main difference between the rear and front pegs is the spring/ball bearing contraption that holds the peg in the upward position if you can figure out a way around that you should be able to fit the monster pegs. Here's some pics.
BTW you can adjust the angle of the pegs the rear pegs are obviously just mocked up
awesome, those look great! when you say the rear pegs are adjustable, do you mean the mounting mechanism allows the angle to be changed, or is the pegs themselves that you purchased which allow for the adjustments?
the angle of the peg is adjustable. Basically, the peg is unversal and is bolted into a model specific mounting bracket. Although there are plenty online that offer adjustment.
Sweet! I think I might have to order a pair of those for my passenger pegs...
