One of the first things I do when I buy a V11 is cut the wires off the 30 amp fuse and solder them together, it shouldn't be there, I have replaced the TPS.
What you talking about JJ?
What's JJ ?
The Guzzi ECU circuit is pretty robust but loss of power for a split second will upset it no end,
The ECU is connected to the rest of the bike by just one wire.
To check for loss of power wire a small lamp to the petcock fuse.
Any flicker of the lamp signifies loss of power.
I like to use a small 12V LED for this taped to the bars.
