Steve S Posted May 3, 2014 Author Share Posted May 3, 2014 One of the first things I do when I buy a V11 is cut the wires off the 30 amp fuse and solder them together, it shouldn't be there, I have replaced the TPS. What you talking about JJ? What's JJ ? Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted May 3, 2014 Share Posted May 3, 2014 The Guzzi ECU circuit is pretty robust but loss of power for a split second will upset it no end, The ECU is connected to the rest of the bike by just one wire. To check for loss of power wire a small lamp to the petcock fuse. Any flicker of the lamp signifies loss of power. I like to use a small 12V LED for this taped to the bars. Link to comment Share on other sites More sharing options...
