dangerous Posted May 5, 2014 Posted May 5, 2014 Hey so, can any one shed some light on this... 05 and cams rebuilt why do you think that would be? have heard of it on earler bikes, I think. Now a friend is looking at it and and that price its not to bad. http://www.trademe.co.nz/motors/motorbikes/motorbikes/sports/auction-722155101.htm
docc Posted May 6, 2014 Posted May 6, 2014 I would think the most likely issue is that a PO let the oil level get low enough and accelerated hard enough to starve the oil pick-up.
dangerous Posted May 6, 2014 Author Posted May 6, 2014 Ok a little info from a local, the story is the oil filter came loose causing a loss of oil to the cam, ca that happen does the warning light not come on? Clutch well aparently they are prone to cracking??? starter... I duno
GuzziMoto Posted May 6, 2014 Posted May 6, 2014 Sure, the warning light comes on to tell you there is no oil pressure and that expensive parts no longer have enough oil to prevent direct metal to metal contact. But unless you were already at idle when it happened it is likely too late to prevent at least some damage from happening.
