v11 lemans fuel vlave trouble
Guest guzziman
havebeen having trouble with my cycle not running dealer says mughtbe fuel valve anti tip over ,any help?
"vapor lock" and "tank suck" FAQ
...sounds like your tip-over valve isn't oriented vertically as it needs to be, causing vacuum to build in the tank. The valve should be removed, or just lashed to the frame to keep it vertical(which is what I did). The other option is to remove the red rubber sealing plug under the tank cap, but I don't recommend that, as that just addresses the symptom(the tank not breathing) instead of the cause(the tip-over valve).
al
