sp838 Posted May 27, 2014 Share Posted May 27, 2014 just to double check, when the ignition key is turned to the on position but the engine isn't started yet, these lights should come on: -N -Oil -Charging -Fuel is this correct? I finally got my new cluster all wired up, tested it, everything works except for the low fuel light which isn't coming on. I did reconnect the leads coming out of the tank to test it. if it's not supposed to come on I won't take it apart, but I'm pretty sure I remember that it is indeed supposed to. arrgghhh..... Link to comment Share on other sites More sharing options...
luhbo Posted May 27, 2014 Share Posted May 27, 2014 The tank is empty? Link to comment Share on other sites More sharing options...
sp838 Posted May 27, 2014 Author Share Posted May 27, 2014 no, there's gas in the tank. I haven't been on the bike since November so I don't remember if the low fuel light is supposed to turn on along with the others when the key is turned to the "on" position before starting, or not. Link to comment Share on other sites More sharing options...
czakky Posted May 27, 2014 Share Posted May 27, 2014 The low fuel light shouldn't turn on unless fuel is low. Link to comment Share on other sites More sharing options...
sp838 Posted May 27, 2014 Author Share Posted May 27, 2014 ok that's a relief. I wasn't looking forward to taking it all apart again. Link to comment Share on other sites More sharing options...
mznyc Posted May 28, 2014 Share Posted May 28, 2014 Link to comment Share on other sites More sharing options...
sp838 Posted May 28, 2014 Author Share Posted May 28, 2014 tested it by running some juice directly into the appropriate wires in the harness, all good. Link to comment Share on other sites More sharing options...
docc Posted May 28, 2014 Share Posted May 28, 2014 There is nothing like having a known good V11 to pull your bike up next to for comparison. Or, as that is known in these parts: V11LeMans.com! Link to comment Share on other sites More sharing options...
AndyH Posted May 29, 2014 Share Posted May 29, 2014 The low fuel light shouldn't turn on unless fuel is low.Even then, not straight away from cold. Takes a little time to 'heat up'. Caught me out before! Link to comment Share on other sites More sharing options...
stewgnu Posted June 8, 2014 Share Posted June 8, 2014 just to double check, when the ignition key is turned to the on position but the engine isn't started yet, these lights should come on: -N -Oil -Charging -Fuel is this correct? I finally got my new cluster all wired up, tested it, everything works except for the low fuel light which isn't coming on. I did reconnect the leads coming out of the tank to test it. if it's not supposed to come on I won't take it apart, but I'm pretty sure I remember that it is indeed supposed to. arrgghhh..... Hmmm, that's interesting... Aside from my dicky neutral light, I don't seem to have the charging or oil lights lit up either... Low fuel light still works though so I suppose I should be thankful ... ? Link to comment Share on other sites More sharing options...
docc Posted June 8, 2014 Share Posted June 8, 2014 just to double check, when the ignition key is turned to the on position but the engine isn't started yet, these lights should come on: -N -Oil -Charging -Fuel is this correct? I finally got my new cluster all wired up, tested it, everything works except for the low fuel light which isn't coming on. I did reconnect the leads coming out of the tank to test it. if it's not supposed to come on I won't take it apart, but I'm pretty sure I remember that it is indeed supposed to. arrgghhh..... Hmmm, that's interesting... Aside from my dicky neutral light, I don't seem to have the charging or oil lights lit up either... Low fuel light still works though so I suppose I should be thankful ... ? Stew, Sounds like time to make certain you are good at Fuse 5 and especially Relay 2 (Headlight Relay). Link to comment Share on other sites More sharing options...
stewgnu Posted June 9, 2014 Share Posted June 9, 2014 Thanks Docc, fuses all good, will check relay tomo.. Link to comment Share on other sites More sharing options...
