The end is all chewed up. I put a new one in, but even the new one sits too low for the valve adjustment screw to properly reach. Before I start tearing things apart, what should I expect?pushrod1.jpg
the cam or the follower are disintegrating? I wouldn't ride it..  have you got the Roper plate? oil starvation comes to mind..
Cams and tappets are fed by splash, plate won't help there. If the adjuster won't take up the slack though the only real option unless the pushrod has collapsed is a buggered cam and tappet.
Pete
The cam and lifter have failed and the greatly increased valve clearance thus created has hammered the pushrods into what you now have.
The cam and lifter have failed and the greatly increased valve clearance thus created has hammered the pushrod into what you now have.
